changing water pump on Suzuki 115 4-stroke
capt g
When changing the water pump on this 2001 engine......
should I use gasket cement or just replace the new pump and seal as it comes in the water pump kit? Thank you for your response.
Capt. G
Re: changing water pump on Suzuki 115 4-stroke
the best thing to do is just use the kit
and make sure everything lines up
then your set.8)
capt g
then your set.8)
capt g
Thank you.
Capt. G
