changing power trim
SBret1
Good evening all,
I just picked up a 2004 Trophy 1802 w/around with a 115 merc EFI saltwater series ob, the trim moter needs replaceing, eventhough it still works it is so rotted out that it wont be working for long, I replaced all the zinks and cleaned all connections so this does not happen again but the damage is done and I need to replace the trim moter, I have no experiance with this job but would like to do it myself, is this job as straight foward as it looks, it looks as though a bracket will have to be unbolted and swung foward to remove the 2 back cap screws on the pump, is the unit under pressure, how would I drain it, just unbolt it? a step by step procedure would be nice if anyone is interested,,,,,thanks for any help.
RRitt
Re: changing power trim
can you take out bottom pin and spin the trim system on the piston shaft? It won't hurt the system.
Faztbullet
You are correct on removing side bracket to gain access... just get plenty of PBlaster,MAPP gas and study up on cuss words about engines in salt water:D
