Changing Marker Light Bulbs
whozleft
Hi all,
I just bought a 1998 ShoreLander trailer and a marker light is out. I can't get the lens off the light to change the bulb. I am sure this is because it's a sealed unit against water intrusion.
So what is the procedure for replacing the bulbs? Do I need to remove thje light from the trailer first?
I figured I'd ask the experts before I broke something.
Thanks for the help.
Gary
roscoe
Re: Changing Marker Light Bulbs
I hate those dang Shoreland'r trailers, and all their non standard parts.
The last 2 I had, I needed to replace either the bulbs or the entire light.
Replaced the light to a more conventional and readily available light.
On the factory marker lights, the lens pops off from the silver (plastic) frame.
I used a tiny flat screwdriver, put in in from the side, pried it off.
If you go from the top or bottom, you will almost surely break it.
On the 2 that I had, you had to get the lens off before you could remove the light housing base.
whozleft
Thanks Roscoe
Thanks Roscoe
I may be switching them out at some point if this is what I will be running into. I appreciate your help.
