littleboater
Thread starter- Joined
- Aug 1, 2006
- 3
ok,i know im a newbie and first time boatowner.i got the pelican/predator on a trade for a cheap quad and a shotgun.anyways,ive already run the engine in a 55 gal drum filled to the top halfway up the l/u.it starts perfect,shifts great,aand shot water 9 feet out of the barrel when i opened the throttle up.still i read on here its a good idea to change the oil in the l/u every year.heres the rub.i found the fill and vent caps(fill on the bottom and vent on top).now if im correct i take both plugs out to drain the oil.but with the fill plug on the bottom how in the heck do you refill it?turn it upside down?thanks for your time.i figured i had better ask the pros.by the by this motor is so clean that you could eat off it inside or out and i just want to do right by it.by the way the model number is 152y9a.what does the y stand for?
