Changing Ignition
gshldon
I am thinking about converting my ignition over to something different. Just thought i would ask the experts what would be the best ignition to convert to and what would be the end results of doing the conversion.
Thanks for the input.
Re: Changing Ignition
Ayuh,... Pick up a Used T-Bolt IV,+ throw it on...
It's about the Best available....
180shabah
Is there a problem with your current setup that a proper tune up wouldn't cure? It would be a whole lot cheaper.
If you do need replacement - vote #2 for the TBIV.
wca_tim
TB iv is an awesome ignition! find a used one and go for it if you need to change. the distributer wonn't be expensive (either v-6 4.3 or v-8 305 or 350 will work fine, just different cap for 4.3).
If you want a nice upgrade... I would probably buy a tb iv distributer and instead of the merc ignition module, a crane hi-6m cd ignition box can be had for about the same price as a tb iv ignition module. They trigger great of the merc distributer and are an easy install. Includes slectable advance curves, a rev limiter (that you set the rpms), and multiple spark discharge below 3000 rpms. they work well and are a reliable product that many have been using for years. and before anyone says crane is no more, s&s purchased crane and has the ignition systems as well as motorcycle valve train products back on the market already...
gshldon
Thanks for the replys guys, and there is nothing wrong with the ignition i have i was just wondering if by changing it over if i would really gain any performance from the engine. It runs really strong now and was just toying with the idea..
180shabah
hp gain, if any, will be low single digits. not enough to make a difference in a car, let alone a boat.
wca_tim
the place where an aftermarket multiple discharge ignition makes a huge difference is running a long duration camshaft. it smoothes out idle a lot, makes starting easier and can dramatically improve throttle response at lower rpms...
The crane set up is nice because it includes both a number of advance curves and a rev limited that you can set.
not going to be worth any power on the top end - at all I don't think. the merc ignition is really a good set up and is more than adequate for all but the most extreme engine builds...
imho
