changing gimbal ring
dieselmax
hi i have a 1973 mercruiser 1 drive with the trim limit switch on the top of the gimbal ring and i'm looking at replaceing the gimbal ring because it's cracked my question is can i put on a gimbal ring with the trim limit switch on the side if i change the piece that bolts to the outside of the transom
Re: changing gimbal ring
Ayuh,... I believe you'll have to swap out the Complete transom assembley to do that....
dieselmax
even the inner transom plate? and is that a better style setup?
Haut Medoc
Ayuh, I agree...^^^^^ :D
It will be easier & cheaper to replace the entire transom assembly with a used one of the same vintage....
They turn up on ebay now & then....
Get one that is from the midwest or Great Lakes that has only been run in the sweet water.... ;)
Haut Medoc
No, the inner transom plate will still work.... ;)
There is no benefit to using the newer style trim switch on your rig....
You should be able to tell by ear & gauge where your drive is at....
The switch in the upper only kills the trim pump in the trailer position.... :)
dieselmax
thanks for the replies gonna see if i can get mine welded before i go buy anything
flargin
If you don't have anyone local, you may check for "Ron Bender", I think he is in FL. He welded mine and has a kit for install of some of the later units (mine is a bravo unit) Knows his stuff, good guy to work with, gives you his cell # to call... I would hate to see his cell bill :eek:
