Re: changing color of boat (winter project) best way to do it?
Hello again Winter..
Is there a reason that you want to roll and tip ? No place to spray im assuming ?
Your wanting to prep..roll on primer..then reprep..and roll/tip topcoat ? am I getting this correct ?
If your dead on just the roll and tip ( you kinda have to give us a direction of what kinda of paint here..dont ask me because I only deal in high end stuff ) then you have to keep in mind about your RED final finish..
RED IS TRANSPARENT !! meaning..your not going to cover like you think you are even in a spray application..not to mention a roll and tip off !
Your going to be applying..sanding..applying sanding...etc ( probably 5 coats depending on what your paint is ).
Now IF..you were to gel this..simple stripe..You would sand with 80 grit and Spray 4 coats. Then sand with 320-400 then 600 (lightly) then 1200..then buff till its a friggin mirror. No worries about dust..spiders doing the ol' repelling trick down the side of the paint ..etc..
IF you decide on the Spray of top of the line AWLGRIP ( or AwlCraft2000/Imron ). Then I suggest sanding your gel to 120 grit..prime with 2 part epoxy primer ( like US paints 545 or Awlquick ) .. then sand with 360 .. wash/clean..clean..clean again..then tack rag then spray a coat or 2 of Yellow before you spray your RED..( to cover your primer as a base ). Then after the 3-4 coats of Red is on..wait for a week and then wetsand with 2000 grit ( your going to have orange peel after that many coats ) and buff/polish 2-4 times.
Now if your going to do the Rusto or Inerlux perfection or equivelent then you have to wait for someone else to respond. Sorry..I dont do those things.
I say Gel-Coat it m8..
.. your learning curve is lower with this stuff and expense is lower..and the outcome is just as good if not better then even the best Marine grade paints !.. You just need to find a spot for 3 hours to spray it ( and its not paint and will not atomize as much as paint.. Ive done just what you have there in a garage.
GET A RESPORATOR no matter which way you decide..
IF you decide after Considerable Reading and Research that you want to go the Gel way..let us know ( We/ I will be here to guide you though it ( its EZ
YD.
PS. If anyone wants to tell you its just so simple to Paint a boat just like that has had many many years exp to back them up ( like me yes and others here ) but for a first timer..its not Real World your going to do what We do..expect less quick result and expect more time and labor/$ .
PSS. I see no reason not to consider BaseCoat/Clear in the application if you find a color that meets your likeing
.. JUST please dont say a metallic color catches your eye
.. that would be a long post hehe.
