tallcanadian
- Sep 7, 2006
- 3,245
is there a larger rim that will fit my 4 lug trailer wheel? i believe they are 4" bolt circle diameter.
The lug pattern for most 4 lug trailers is 4 on 4". A 4" bolt circle is closest to a 100mm pattern on some Ford Escorts but those rims have the wrong offset.
Just replaced my 570-8 tires/rims with 530-12 tires and rims. Both 4 bolt rims.
Needed the extra load capacity and had clearance under the fenders so the switch was easy. The 12" tire is 2" larger in diameter so I now have 1" more ground clearance but thats no big deal to me.
Whats the reason for larger tire?
Great lead on the tires, the prices are the cheapest i've seen so far, about $20 less per tire & rim set.
