changed impellor and no water
JUSMARCEL
It jus keeps gett'in better, 82 merc 70 hp 3 cyl. ser. 6163931, got her running was told i better change impellor, watched a video via u-tube read up on it and changed it, did have trouble getting it back in but wiggled flywheel and it seated. i have taken it apart twice and can't find what i did wrong. will try again tomorrow. could i have overtightened the housing, made sure key was in place and tube was in place kinda stumped. let the games begin.
BonairII
Re: changed impellor and no water
This seems to be a popular subject lately. I had the same problem not long ago with my '77 75hp.
Make sure ALL the impeller vanes are going the correct way. The shaft should be turned clockwise and you slide the housing over the impeller. When I did mine, I got the impeller in the housing then slid it the housing down on the key. Had to get my face really close to make sure it was going on the key properly.
Obviously, make sure that the plumbing from the LU mates with the intake pipe in the leg, too.
oldman570
Motors run on muffs will sometimes take longer to pump the water like it would if on the water. The Lu will set deeper when on the water and will prime the pump better. The stats being closed will also slow the water flow till they open. If any of the old impeller was missing, the missing parts can plug the water jackets and pee hole also. Use weed eater string and run it up the pee hole to clear any plugs in it.
Oldman570
JUSMARCEL
well they say try, try , again. third time the charm, not sure what was wrong. tore completely down re-keyed turn shaft clock-wise as i put pressure on housing, maybe did not tighten as much. but everything is working thanks as always for your wise input. happy boating, marcel
