Change From SP To DP? 4.3GL
dtescher
I have a 1997 VP 4.3GL PLKD #4110144649 SX-C1 1.85 #4112030094
If it's possible to change the lower end to DP what gear ratio will I need to look for?
And in the end is better to just find a boat with that already? I love my boat
and I have spent some blood, sweat, tears and $(not a lot) getting her near perfect. Any advice?
dtescher
Re: Change From SP To DP? 4.3GL
Thanks Don S. I will. Much appreciated!
dtescher
Whoa!!! That's more than I paid for my boat! I guess I'll have to save up or find a boat with a DP already in it.
Don S
Some lucky people have actually found good used lowers for less tha 2K. Just keep an eye out until the opportunity strikes. Of course with the DP drive, you need DP props and they go for around $800 by themselves new. (that is the aluminum ones)
Makes that single prop look pretty good doesn't it.
dtescher
Absolutely! I will keep a look out for some deals. Thanks Don S.
Taz59
Dtescher
Just wondering what are the benifits of swapping over to DP ????
jerryjerry05
The twin props make for better acceleration,better tracking(no wandering).
bruceb58
I know for larger boats, it definitely is a huge benefit. I would never own a boat without one again. I get up on plane in seconds. Not sure the benefit is really that great for a 18' boat though.
The props are very expensive. Been awhile since I bough a set of stainless for mine but they were over $1200/set.
As far as better tracking, that is only at idle speeds. Backing up is also a lot easier. Again, this helps a lot more for larger boats.
Taz59
Does it make the boat go faster
bruceb58
Likely slower but not much.
