89 resorter
- Oct 3, 2013
- 287
Now that the weather had (kinda) improved here in South Western PA I have begun digging into the restoration of a 89 Century Coronado that I purchased in late fall. I have been following you guys on this dry dock forum for quite some time so I pretty much knew what I was getting myself into when I bought her. I was not aware that our winter was going to be so brutal so I am nowhere near where I thought I would be by this time of year ..... I have an un-insulated building that is normally quite comfortable to work in when temps are upper 20's or so. I found out quickly that it is not comfortable to work in when the temps are more like 15 or less! Anyway, I got started and wanted to share some pics because the only thing I know about the boat refurbishing process is that I am going to need a lot of help and will be asking a lot of questions. What I know so far is that the motor has 500 hours and runs very good and has good compression (at least it did on the test drive) and all I plan to do with it is to have the carb, starter, waterpump, fuel pump, etc. rebuild/replaced. The whole rest of the boat is another story as it lists to the starboard side which I have already confirmed is due to wet foam. After I had confirmed that the foam was wet, I found the culprit when I removed the swim platform and saw that the bracket on that same side had been bent and pulled the lower lag screw out of the transom. The PO tried to fix it using what looked to be a lead plug and installing a smaller diameter (steel) lag screw. I plan on pulling up the floor this coming weekend with the expectations being that the stringers will have rot and likely the transom in that area as well. I will warn you that this will not be the quickest project you ever see on this site. I only have the weekends to work on this project and that will be when I don't have a forced shore pass from the Admiral wanting me to do other missions. My goal is to have it ready to launch by Summer 2015 which is fine since I have lots of friends that owe me boat rides until then.
