Hopefully this picture will show up.
If it does, here is my problem. This picture is somewhat confusing due to the perspective. I am trying to show the center stringer that is directly in front of my engine. It was very water logged and rotted. I cut it out to solid wood and now am in somewhat of a quandry as what to do next.
I realize that to do the job correctly the stringer should be replaced, but to do this would require removing the engine. I don't really want to do that.
What do you think of building a "plug" to replace the cut out portion, then sistering & glassing two pieces of 3/4 ply on either side of the plug and tabbing this to the hull with mat and tape?. The combined thickness of the two pieces of ply would equal the original thickness of the stringer. As can be seen in the photo, the lower portion of the stringer next to the bottom of the hull is still in good shape.The sister pieces would extend about two feet on either end of the plug and I think that should provide enough strength to the stringer.
This question is unfortunately the first of a number of stringer questions I will be asking in the future as I have discovered a number of some what difficult problems. You folks have proven in the past however to be very helpfull and I am sure many have better insight than I. Any help would be greatly appreciated.
![1zqufiw.jpg](http://i6.tinypic.com/1zqufiw.jpg)
