Re: cd14 wont run
Yreka !!! I might have found the problem.. Took off the head and there was a large crack in the gasket going from one cylinder to another. The crack had a white burn mark through it. Have ordered another head gasket. It will be her Mon or Tues.
Instructions for installing the head gasket on the CD14. Does anyone have the lbs. torque that the head bolts have to be set at ? Do I use any gasket sealer ? I think that this cracked and burned gasket just may have something to do with the low compression and moisture getting into the cylinders. Comments please, just dont call me a dummy.
