CB Antenna?
jbing81
Hi guys,
I searched the forums but didn't come across anything on the subject so if its already been asked i apologize.
I just picked up a Cobra DSC radio today and want to know if I could use a CB VHF antenna rather than spend the extra money on a marine antenna. The antenna that I have is a 6' SS antenna with a SS ratchet base.
I still have to pull the antenna out of the attic but from memory the plug looks the same.
Thanks for the advice in advance
Jeff
NYBo
Re: CB Antenna?
CB isn't VHF, and it isn't anywhere near the same frequency band as your marine radio. Won't work worth a hoot and you risk damaging your radio when you transmit due to the mismatch.
jbing81
Re: CB Antenna?
That's why I ask these questions. I wasn't too concerned with damaging the radio as much as I was opening the door to the attic =). Its home to just about every typical "attic" item known to man! And requires a tight rope act just to get around up there!
Thanks for the heads up! I can once again forget about the CB antenna somewhere in the attic lol
