marksa1458
Thread starter- Joined
- Apr 6, 2009
- 93
I have a 14' runabout with a 1964 Merc 500 short shaft on the back. Engine runs great and pushes the boat to 35 on the old Airguide gauge that I have. My problem is that when I give it full throttle, take a turn or hit a sizable wave the engine RPMs will increase with no forward movement. If I back off the throttle and then increase the throttle slowly the engine will be fine. I thought I had a spun hub, so I had the prop rehubbed, which has reduced the problem considerably - before I had the prop re-hubbed it was very difficult to get the boat going and I had to very gently increase the throttle.
At this point, I am a bit stumped. I have tourqued the prop nut to 55 lbs.
Any thoughts and help would be appreciated. Thanks,
