seahorse197220
- Feb 26, 2012
- 73
First, is the plate above the prop called a cavitation plate or a ventilation plate? Second, how far below the boat should it sit? Thank you.
This is what I am working with. It is a fiberglass boat. It is a 1972 20 hp Johnson short shaft. The problem I am having is, am I going to have to cut the boat in order to get the plate low enough?
The Mercury Installation instructions recommend mounting the motor so the Anti-Ventilation plate is Zero to one inch (0.0" to 1.0") below the hull.
And, 1 to 4 inches below the hull at speeds from 50 to 80 mph.
If your water intake is on the botton of the Anti-ventilation Plate, having it above the keel could overheat the engine while on plane.
Before you start Cutting it up consider a Jack Plate.
Would a jack plate lower it? The setting he is at is the lowest setting for a jackplate... no? He needs a different length shaft... well, the engine does anyway.
Lowering the engine stops proper tilt/trim. Jackplates enable raising the engine from its original spot....and lowering back to its lowest spot (which is where it is at now).
