FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I have a 19 foot Horizon with a 1996 40 horse force motor when operating at idle or just above it is fine, when you throttle it up it cavatates terribly as you decrease power it goes away any ideas?
motor too high, load on boat balanced wrong. too much weight forward. i have a 140hp on my boat, i have to throttle up slowly, then get faster. proper prop for the application would help also.
If this is a new developement it may be a spun hub.Put a indelible line across the underside of the hub run the boat and check the line.You can get the hub repaired at a prop shop.
