Carburetor Issues
UKROYAL
I have a 1999 Bayliner Capri 1850 with a 3.0 liter Mercruiser. The carb is almost trash and I am looking to buy a remanufactured one but I can't find any numbers on it to see what I need. Does anyone know what carb goes on this engine? It is electric choke and 1 adjustment.
Also does anyone know what the rotation is for the propeller? Standard or counter clockwise. I believe it is counter.
Thanks
fat fanny
Re: Carburetor Issues
It's a Mercarb if it were a rochester it would have 2 air idle mixture screws.I went through the same issue last year and aftermarketmarine was the only one that was able to help me with a universal kit that fits all mercarbs but unfortunatly the only way to find out what number carb it is is to dimantle it and I believe the venturi number is the only way of telling which one it is along with it's jet numbers if I remember correctly. And I belive if you know your outdrive model number the service manuals in the adults only section can identify rotation direction.
jerryjerry05
Those small Mercruisers all are standard rotation.The only way it would be changed is if somone changed the lower for a counterotating one.Not likley.J
