After rebuilding the carburator on 1967 3 hp evinrude ,it requires partial choke to run motor , stalls out without it
Did you replace the gasket behind the carb? Could be an air leak causing it to run lean.After rebuilding the carburetor on 1967 3 hp evinrude ,it requires partial choke to run motor , stalls out without it
