Carburator requires partial choke to run
Sgt paul
After rebuilding the carburator on 1967 3 hp evinrude ,it requires partial choke to run motor , stalls out without it
That means there is a blockage in the carburetor !----------If it has a fixed high speed jet screwed into the bowl it needs to be very clean
boobie
If it has a fixed high speed jet it requires a bowl gasket around the high speed nozzle.
jimmbo
When you say "it requires partial choke to run motor , stalls out without it". Does that mean it won't run at all, or won't idle, or idles fine but dies at speeds higher than idle?
tomhath
Master Chief Petty Officer
After rebuilding the carburetor on 1967 3 hp evinrude ,it requires partial choke to run motor , stalls out without it
Did you replace the gasket behind the carb? Could be an air leak causing it to run lean.
Sgt paul
It will idle now after recleaning , all new gaskets and needle , it has only one idle screw on top ,bottom is sealed , set it at 1-1/4 turns out runs fine at idle , with choke in but now it dies when I give it more throttle ,
The bottom is NOT sealed !----------There is a fixed high speed jet in behind that drain plug.-----Find it and clean that jet.
