Carb settings ,1968 johnson 33 horse
kikkup
just rebuilt the carb and was wondering what the settings on the air mixture..
66evinrude
Re: Carb settings ,1968 johnson 33 horse
hi screw 3/8 from seated low screw 1 1/4 from seated
BonairII
Remember those settings are 'starting points'. Once motor is warm adjust low speed again. You'll have to dial in high speed mixture on the water at WOT
kfa4303
Banned
HI kikkup. Welcome to iboats. This link should help you get the carb set up. Be sure you run your motor in a test tank with water filled up to about 1-2 inches below the exhaust port. These older motors can't run on muffs. Good luck. Keep us posted.
http://forums.iboats.com/showthread.php?t=167352
