steves86ta
Thread starter- Joined
- Jan 15, 2013
- 56
Hi Guys,
I got the new engine in the boat last weekend and headed out to Perris yesterday to get her broken in and see how she runs. I was very happy with my results, however I now believe the stock Qjet is too small, or just not ideal.
Here are the specs of the engine;
Vortec 350 (stock bore)
Custom cam (224/224, .503" at 1.5 on a 110* LSA installed at 108)
Stock vortec heads for now plan on replacing with Edelbrock E-Tec's
About 9.5:1 compression
As far as performance goes, the boat runs great. It pulled the 19 pitch prop I already have o 5100 easily and 56.9 mph via GPS. (I could have pulled more RPM if I trimmed out more, but I did not want to run the stock drive that high) I plan to "prop" it down to where WOT is about 4600.
With that being said, the engine really was a dog out of the hole especially trying to Ski. I changed to my 17 pitch prop to try to pull some skiers and it just has a very hard time when going from idle to WOT. Seriously bogged down and had a hard time building RPM from idle. My thinking is that it is either Carb related or Timing related. I have the initial timing set at 10* and it just seems like a huge bog.
So my question is that I want to get rid of the Qjet and switch over to a "traditional carb" I just can?t decide between a double pumper or a vacuum secondary. If this was a car I would go with a vacuum secondary but I do not know if a boat will run a vacuum secondary carb efficiently when you are at RPM all the time. I know most everyone recommends a double pumper when pushing a Jet, but I have an outdrive so would a double pumper still be the recommendation? Also what size I?m thinking no bigger than a 750.
Sorry for the long post, but thank you for any insight you can provide
Steve
Steve
