Carb rebuild time
svb165
And I am getting lost in process of locating and ordering the RIGHT kit.
its a Rochester 2 jet mcm 120/140 1351-8480
Does any one know what the sierra # is ??
svb165
Re: Carb rebuild time
I have tried to find the right listing for an hour and a half. found everything BUT the carb rebuild kit for that carb. any one???
airshot
I bought mine from our local mercruiser dealer that way I knew I had the right one. Just took the numbers off the little metal tag and
bingo he handed me the correct kit.
alldodge
My research says the Sierra kit number is 18-7746 and Napa kit is 18-7097
svb165
Where were you able to find that number if you dont mind me asking.
i can find a kit through a couple of carb shops but useing there numbers no sierra #s
mikecrof
I agree with AllDodge, that Sierra kit says replaces 823427A1. Which was the kit my dealer just ordered for my rebuild of a 2B Rochester and he asked a service guy who said that is the kit they use on all 2B Rochester's regardless of model. The photo looks like it has all the same fiddly-bits that come in my Quicksilver 823427A1 kit.
Any FYI, the power piston does come out, it may have been staked in pretty hard, so it could take a fair amount of messing with to get it to release. I had to use a fair amount of 3-in-1, carb cleaner, and a little bit of pressure using a deep well socket over the shaft and spring so I could gently pry on the flat plate that touches the power nozzle, to get the piston out.
svb165
Thanks guys.
i nailed it down last night too. i couldnt locate a sierra listing for carb kits for some time.
i figured it was pretty standard for a Rochester 2 jet but want to be sure. There are a couple others available.
