1984 johnson 70 been having problems since i got it, tries to stall when giving throttle from start, push key in and it goes fine from there, this only happens from the start. i have rebuilt all and problem hasn't gone away. when under load if i shoot pre-mix into middle carb, it clears and goes. so i took the carb off today to check and there was a brass plug on the top left rear of the carb i wasn't able to get off at last rebuild so i thought the problem may lie there. with a little heat i was able to get it off and get to the jet and remove. it seemed clear but cleaned out well anyway.now here is the problem... this jet and the low speed jet are 2 different sizes and didn't check this first when i took them out, which is which and now i'll go back and check the rest to make sure they are in the correct spots. sorry for the long post but i can't find a diagram of the carb anywhere. thanks in advance
