Carb rebuild kit
Leanabel
Hii Guys I need yours assist
i have Volvo Penta 5.7GS with Holley carburetor(2BBL), I was planning to do some service of my carburetor but I m little bit confused because I don't know which Repair Carb kit should I buy
markings on my carburetor are : 3858334 then 75004-1 and 2978
Please assist
Leanabel
Thanks Scott
One more question do I need to order extra Holley Carburetor Diaphragm,50cc or that one is included in rebuild kit, because how did I understood from another treed in kit is diaphragm 30cc,,Correct me if I'm wrong.
You don't have enough motor to need a 50cc accelerator pump. The kit comes with a 30cc diaphragm
You need more than 500 cubic inches to need a 50cc pump
Leanabel
Btw Scoot do you know maybe which float goes for my carburetor because I was planning to replace him also ?
Seriously doubt you need to change float.
Never needed to change a float in 40+ years of playing with Holley carbs
Go to the Holley website and look up everything you need.
Holley only has 2 vacuum diaphragms. One for externally adjustable springs, and the standard. Your rebuild kit will have it
However I doubt you need more than the bowl gasket and metering plate gasket and a can of carb cleaner
Leanabel
thanks Scott
what you thing would it be wise to change Carburetor Float Spring 20-123 ( Part Number: HLY-20-123) and Accelerator Pump Spring 20-108-10 (Part Number HLY-20-108-10) ?
thanks Scott
You're over thinking it. Use the kit, chase all the passages, put the carb back on and go boating
Those springs will outlast your boat 100 times over
