carb kit
dirty d
do you know of a COMPLETE carb kit that matches with the kd 1A carb. I find gasket kits all day, but none with the low-speed needle and associated carb rebuild parts.
Chris1956
Honorary Supreme Mariner
Re: carb kit
Look up that motor the Crowleymarine.com web site. They wil tell you if the idle needle is still avail. Why do you want to replace it?
Faztbullet
Re: carb kit
OEM number 1395-92621. Has all the parts,gasket,needles ,springs and screws and are about $77 ea.
dirty d
Re: carb kit
Short answer to your question chris1956, is I wanted to do the rebuild with new parts, and instead I only replaced the gaskets. The needle spring seems to have lost some spring, but mostly if any part were in question I probably couldnt tell unless it were obvious. Thanks for answering my questions too.
