nphilbro
Thread starter- Joined
- Dec 19, 2011
- 304
Model E200849R
My motor was acting up a bit (rough idle and noticeable hesitation at transition point of about 2000ish - 3000ish rpms) so I decided to do a simple carb cleaning.
I pulled the plugs on the 2 jets located on each side of the carb (12 total) and fished bare 24ga copper wire through the small (top) ones and the same copper wire with the jacket through the bottom ones and sprayed the mouth and jet ports with carb cleaner.
I also did a Joe Reeves style link and sync. After all this the idle on the muffs went from a bit rough to quite smooth. Even completely sealed up this motor is too loud to run long enough in the driveway to warm up so I could only let it idle for 15-30 seconds at a time 2-3 times over 20 minutes without getting another love letter from the HOA so I'm not sure what the final outcome will actually be but it was noticeably better. BTW, I'm basing my comparison on a very rough idle on the muffs last night.
A couple questions:
Are the top jets on each side of the outside of the carb air mix jets?
Are the bottom jets on each side of the outside of the carb the idle jets?
Where is the high speed jet located?
I've read in other posts that on some of these 200's they increase the jet size by 2 to compensate for ethanol. ALL gas in my part of Washington is "up to" 10% ethanol but I'm not sure what re-jetting would actually do other than possibly make it run a bit cooler. It seemed to be running pretty well my first time out before I switched to a new tank that had bad fuel (that I just bought) and both this motor and my kicker got plugged and died. The jets I pulled from the top carb (prt/std) and middle (stb) are all #31 which indicates it's at least the original jet/size based on what I can read of the stamp on the carb body.
I don't really have the time at the moment to pull all three carbs for full breakdown and rebuild but I'll probably get to it in a few weeks. In the meantime I hope this simple cleaning/timing/throttle link adjustment will get it back to spec. At least now it hits max advance *before* WOT!
Thanks,
NP
A couple questions:
Thanks,
NP
