That's not an electric choke, it is a primer solenoid. When you push the key in while cranking the solenoid opens a fuel path directly to the intake. It is not a pump however. You must pressurize the fuel system with the primer bulb for this to work properly,. The red lever can be turned to open that fuel path for manual priming should the battery be dead. This allows you to rope start the engine.
