Carb /choke problems
Manchu1
I have a J25EETC need part # for what i think is the electric choke. The part has a red lever on it and leaks when it is rotated downward 180, any advice helpfull
gm280
Manchu1 :welcome: aboard to iboats...
It seem you engine is a 1993 Johnson 25HP and I can find every part number for most every part for that engine. But they don't show or make any mention to a electric choke assembly. It looks like one is used because there seems to be a clamp for it in the break-down reference pictures, but not shown or any part number. So maybe those familiar with your model engine will chime in and help out... Sorry I couldn't find such a part or the number... :apologetic: :sorry:
Manchu1
I have lookeed all over for the part # not to be found.This helped out alot . Have a great day
Honorary Supreme Mariner
????------Should be easy to replace the o-ring in there.----Hurry to a dealer to get the parts !!
Silvertip
That's not an electric choke, it is a primer solenoid. When you push the key in while cranking the solenoid opens a fuel path directly to the intake. It is not a pump however. You must pressurize the fuel system with the primer bulb for this to work properly,. The red lever can be turned to open that fuel path for manual priming should the battery be dead. This allows you to rope start the engine.
Manchu1
Thank guys for all the info . Boat is running strong(replaced the whole top of solenoid). No leaks.
