carb adjustment
emmaloulov
I have a 1968 evenrude fastwin 18hp I use for trolling mostly, It is running ruff at low speed and I think is getting to much gas at low speed, I can'nt see any place to adjust the carb, could someone please post a picture of the carb showing where the ajusters are located, Thank you so much
kbait
Re: carb adjustment
If you look directly above the carb throat, there is a needle valve that screws into the carb. That is the low speed jet. Start at 1.5 turns out from lightly seated, and adjust from there. Good luck!
