Car audio wire used as extention for yellow and red ignition wire
Jaysalman
can I use a wire from a car Audio radio player to extend my red and yellow ignition wire that goes to the slave solenoid on my 3.0 merc 1989?
Jaysalman
What could I use, just as a little extension I noticed the wire wasn’t straight at some point it was bended so I cut it
GA_Boater
It was bent so you cut it? Wires are always bent. You probably cut off a good wire.
Use the same gauge of marine wire as what you cut off.
Jaysalman
Well I was having some issues with the starter just clicking so I thought mayb it was bad through that wire
but yeah we’re do you think I could get some of that wire and how to figure out what gauge wire it is
GA_Boater
Skip getting wire. Go to the auto parts store and get some waterproof crimp connectors. They have a sealant and heat shrink tubing. Put the ends of the wire back on.
Then start troubleshooting why the starter clicks. Could be the battery or corrosion on battery cable connections.
