jigngrub
- Mar 19, 2011
- 8,155
Re: Captain Chair ripped out of deck
Zee nuts (the proper name for tee nuts) are factory installed because of their flush fit on the underside of the decking and will not interfere with framing members or other possible obsatcles commonly encountered with washers, nuts, and backing plates. They're stainless steel and the proper application device.
I can see where the toggle bolts would be very handy for an inaccessable under deck application and they would be my second choice. Toggles are very strong, but have their limitations when obstacles are encountered.
An adhesive would be ok if you wanted extra insurance, but would only bond to the deck finish material i.e paint, carpet, vinyl.
Agreed .. chairs are Not repaired with Toggles or T-nuts .. they are through bolted..
If you want a quick "epoxy filled" hole that you can "re-screw" your doomed to the same fate as the OEM .. and that is wrong.
Toggles..good luck with them. .. Not the right way..
Id put a Pie in there and Through Bolt them puppies if at all possible ..
YD.
PS. Got pics yet ?
