capri interior
fngboater
hey all i have a 96 bayliner capri classic 1950. my questions are ...
1. What are the cutout dimensions for the rear removable jump seat bases? There werent any there when i bought itso i need to make them. I know that they should also be able to fit up on the engine cover to make a sundeck. My other question is...
2. Does anyone have the dimensions for either of the two 9 ft long side panels. mine are partially there but the plywood just falls apart when i try to pull the old vinyl and foam off to get better measurements. which is also why i just cant measure to make my seat bases.
3. Last question is what is the cutout size for the foam on the motor cover? mine is not there and the po used roll on bed liner. I HATE IT. which brings me to another(im sorry)question.
4. My motor cover doesnt have any cup holders in it (not even previuosly cut out). do the original motor covers with the cup holders have any sort of insulation around them or are they just plastic exposed to the warm engine(making it great to kepp your coffee warm)
Any how thankyou for reading this and any help will be greatly appreciated.
timolad
Re: capri interior
I have a Capri 2150. I'm not sure about the measurements you are asking for since y boat is a different size.
I can tell you the cupholders on the engine cover are not insulated in any way. Mine have short, clear tube which I assume is to drain any fluids away from the engine into the bilge.
