Cant read numbers on carb
jimbo1229
So im trying to get a rebuild kit for my carb but the numbers that i thought i read are not coming up with any results for a rebuild kit?? Its very hard to read the numbers on it, is there any other spots there would be numbers on it?
gm280
Re: Cant read numbers on carb
Well what does the carb go on to? What engine, year, model, HP and such would help a lot. Also maybe even a picture of your carb/engine. Repost with some additional data...
jimbo1229
1992 beachcraft 3.0l gm motor 140hp still trying to find the serial number on the boat the one on the flame arrestor has worn off
achris
More fish than mountain goat
Is it a Rochester or Mercarb? (One idle mixture screw or two?) What numbers do you already have?
jimbo1229
Pretty sure it's a merc carb there is only one screw, numbers I thought I saw is 9562A-2 and I think the other numbers are 2202?
Don S
Should be an engine serial number tag just above and aft of the starter on the flywheel cover flange of the engine.
achris
2202 = made in February 1992
Carburettor part number will be 1389-9562. (Verify that you have a 1.45mm main jet)
Gasket kit part number is 3302-810929004.
Chris.....
jimbo1229
awesome thanx chris, dumb ? when you say carb part number what does that mean? would that be if i replaced the whole carb?
Don ill have to look after work tommorow thanks
achris
That's the reference number you use when referring to the service manual. If you want to order a new carb, the part number would be 3310-806077A2. The number you quoted (9562A2) is also needed to order some parts as they vary by carb....
Check this parts listing and have a look at the comment for item #8
http://www.mercruiserparts.com/Show...sc=Carburetor(Mercarb)+0D447415+Thru+0D836075
Chris.......
BTW... That carb number says your engine is a 3.0L (as opposed to 3.0LX) and the serial number is between 0D447415 and 0D836075... :D
jimbo1229
sweet thanx again but um I guess im gonna have to figure out a way to find parts or custom make them if things are not avaible anymore. the carb seems expensive too. ive seen they vary from $265-$800. What sucks if I try to rebuild it and parts are not avaible ill have a incomplete rebuild>?
achris
Have a look at all the parts in the listing I put the link up for... Only 3 are NLA (and they are not normal service items anyway).... All the rest are still available. Expensive? Yes, but nobody said maintaining a boat wasn't. You're saving the most expensive component by doing the work yourself, the labour. If you find a cheap replacement carb, please, just make sure it's a proper MARINE carb...
Chris.......
jimbo1229
ok so im gonna buy a rebuild kit but it seems the float does not come with it, ive read those usually need to be replaced. Anything i should replace while i have it apart? never really work with carbs before so this is a learning experience for me
