Can't find model number on a 60 Hp evinrude
trucker28
a friend of mine just bought a boat with a 60 Hp evinrude and we were trying to find the year by finding the model number cant find it any were and I mean we went right through the whole motor looking for it any ideas were to find it to find the year of the motor.
psteurer
Re: Can't find model number on a 60 Hp evinrude
Normally, there is a small silverish plate on the outside of the bracket that hold the motor to the transom. If the plate is missing, there is a silver plug (maybe 1 inch in diameter) somewhere on the engine block. The model number is usually there too.
F_R
Honorary Supreme Mariner
Is it two, three, or V4 cylinders? What color is it?
trucker28
3 cylinders and it look someone may have painted but I think it may have been white and green
F_R
Probably a 1970 or 1971. Have a distributor cap under the flywheel? That would be a determinator. Unless it actually is a 1968 or 1969 55hp.
CaptainHook
On the top of the motor in front of the flywheel toward the spark plugs there should be an aluminum plug looks like a freeze plug, this will have the engine's model # stamped into it. This is the info you need to determine year.
trucker28
Thank you I will head over there and try to find that plug
