Cannot get lower unit off - 2004 merc 115hp
carpedium
Tried searching and didnt find anything similar for this engine. The motor is a mercury 2004 exlpt 115 hp, s/n OT919496. The four bolts at the interface between the lower unit and the engine were removed, and it does not come off. What am i missing?
Thanks in advance for your help.
GA_Boater
Did you get the two from underneath? One is hidden by the trim tab and one just forward of that.
mebe007
Should just be 5 15mm nuts with washers. Sometimes corrosion builds up on the studs and they stick. I would try to lightly massage it with a soft dead blow or a rubber mallet.
