Can you tell me what this is?
FREDDYPD
I have this box behind my dash. It has 2 wires coming out. Black goes to ground and red goes to an unknown switch with a propeller stamped on it on the dash. This is on a 1994 Sea Ray Laguna outboard. Can you tell me what it is?
FREDDYPD
Re: Can you tell me what this is?
I am in the process of replacing the existing AM/FM radio. I am thinking of making a new dash out of plexiglass. Would it be a bad idea to move the radio up to the dash?
studlymandingo
Is that a DIN type plug like what connects a GPS to the VHF and the fuel sensor etc.? Looks like it could be something like that or maybe where a GPS would connect to an autopilot.​
tashasdaddy
i would save the space for future use. you already have the cutout for the radio.
FREDDYPD
The box has a receptacle with 3 female pins inside the connection. Not sure what the switch does. I have never had to use it while under way.
I intended to put the radio in the original spot, but the new radio's cover is slightly smaller than the original. I guess if I wanted to mount it in the original spot I would have to first mount a filler plate over the existing hole. I was thinking if I bought new plexiglass for the replacement dash, I could cut a piece off for a cover plate and then bolt the new radio cover to that??
captfeig
That box is probably for the depth guage.
captfeig
