Re: can you run 1993 90hp evinrude without the thrust pin?
what position is the pin in ?it can be removed as far as i understand.ive always thought of it as a tilt pin ,if you have tnt remove it if need be .i know on my boat with basically the same motor its very sensitive to trim because its so light.
