can water pump be rebuilt???????
jodymartin
Boat&motor- 1986 21' bayliner capri-aq225e #cu56837.....
yesterday my waterpump locked up while out fishing.....pulled the pump housing off and the bearings just fell out, what was left of them.... the housing is in good shape....my question is can i rebuild it???? if so were can i get the bearing and the seal.... i hope it can be because the bolts that hold the pully on are all stripped inside......
jodymartin
Re: can water pump be rebuilt???????
I guess there isn't anyone that knows the answer to this one.......
dypcdiver
See the post:- Water Dripping From Behind 5.0 GXib Impeller Housing
Or at least do a search!
jodymartin
I did a search and I seen that post>>>> My pump looks nothing like that one
jodymartin
the raw water pump...on the harmonic balancer
jodymartin
I checked the store but the one it shows as being on my motor doesnot look like the one I have....here is a few pics of mine
dypcdiver
When you said the bolts where stripped, do you mean the Allen headed bolts? These are high tensile steel and very unlikely to "strip" IF using the correct size Allen wrench, from memory I believe it is 8mm. This might be a long job and involve lots of penetrating oil and perhaps some hammering and the careful application of some heat, and if all that fails you might even need an angle grinder. Oh and a bit of swearing might help too.
It has got to come off even if you have to buy a new one!! Have fun, we have all been there.
jodymartin
yes the allen head bolts....and yes they are stripped, I'm not a complete moron I know how to use the right size tools..........update so far I have gotten two of the bolts out by hammering in a larger size allen wrench......the last one is completly round so I put JB Weld on the wrench and now waiting for it to set....I'll let you know what happens
jodymartin
ok the JB weld did not work at all....so i cut the head off the bolt with a p-grinder and got the rest of the pump off......still need to know if anyone can tell me were to get the bearing and the seal????????
PiratePast40
iboats is an authorized VP distributor. Go to the top of the page and click on "Boat Parts and Accessories" and then on "Boat Motor Parts". Just drill down to find your engine and components. Looks like the seal may be difficult to find but they do have the part number listed so you can keep searching with that info. With these older engines, it sometinmes takes a little creativity and searching to find some of the parts.
jodymartin
well I found the bearing at O'Reily auto parts for $8 the part #PT107DD and the seal kit on ebay for $30 volvo part #841642....
