Can the base of engine work? Two to bolts under engine are rusted and can
achris
More fish than mountain goat
I think that's only firing on 3 cylinders. Check you have spark on all spark plugs, check the spark plugs themselves, check the rotor, cap and all the leads.
I'd do a 'plug pull' test. With the engine running, using good insulated pliers, pull each spark plug lead off one at a time. When the engine doesn't change, that's the cylinder with the problem. You should hear the spark 'cracking' as you lift the lead. No (spark) cracking, lack of spark is the problem. You hear the cracking, but the engine speed doesn't drop, you have a bad plug, or a bad cylinder (head gasket, valves etc).
Chris......
liusigou
Chris......
The pressures are 140,140, 125-130,140. Always I can hear explosion voice while trying starting engine. I can see the smoke at the top after the explosion voice
achris
'Explosion voice', what's that? Backfire, maybe?
If it's backfiring, then maybe you have a valve tightened down too far, or the carb is too lean.
Chris...
liusigou
Chris...
Hopefully I can explain it a little better, when I try to start the engine, the engine starts to spin like normal, but after some time maybe a few seconds, there is a popping noise, smoke comes out of the top of the engine, and the engine stops on its own.
liusigou
It runs better and less shaking after I tested the cylinder pressure while the testing pressure. But it seems engine run slower and slower and stop in the end after I put into netural shift. even it stops after put it into reverse shift. I only adjust the lower shift cable on the top of engine. Should I adjust the other two cables?
achris
That sounds like a backfire. Check the valves clearances and the ignition engine timing.
liusigou
I do not know what backfire means. there is an special explosion sound and then I can see the black smoke on the top of engine.
liusigou
I cannot start engine after I mount the outdrive. Link is the viedo of trying to start the engine with backfire. What issue is it? I can start the engine if the outdrive is not mounted. Should I replace all the spark? I think the coil has some issue.
Scott06
That sounds more like a lean sneeze than a backfire. Are you sure its getting gas? check for gas and spark should fire? Also verify the shift interrupt switch is not active as that will ground the spark
liusigou
Today I went to marine supplier with my coil, he tested my coil and told my coil is good. I can add some gas and also replace the spark. But how can I verify the shift interrupt switch?
Scott06
I think you just disconnect the wires at the shift interrupt.
Since it worked then it didn't suddenly, do you have a kill switch at the helm that may be tripped- do you have 12v at positive terminal of coil when cranking
To rule out a back fire (when spark plug fires but intake valve is open) have you done a compression test to verify valves are seating and verified the ignition timing and firing order
liusigou
I have just done a test for starting engine after I added some gas. the explosion and noise and smoke are still there, but did not shake any more. But after I pull the handle to be neutral, the engine stop and I could not start the engine any more.
achris
If the drive is of the boat, check that the shift slide isn't getting hung up when you move the gear lever. If that's not the problem, then it sounds like there's problems with the shift plate, involving the interrupt switch. Learn how the shift system works and then start checking it out.
The continued backfire on starting could be over advanced timing.
Chris...
liusigou
Chris...
Manual#6?
liusigou
Can anybody confirm that the wirings are correct or not for the four cylinders?
Blorton
I just wanted to chime in and say I really admire those of you chipping in and helping the OP, despite the serious language barrier. I am in awe. 👏
liusigou
Sorry. I'd like to upload a picture to confirm the cylinders connections to distributor are correct or not.
