can someone help
andy-1
hi i have a galaxy 190 sport i bought it with just the engine the engine is a volvo penta AQ 151C and i have been offered a 270 sterndrive my question is will this stern drive fit the engine and will i need additional parts to make it run properly the stern drive comes complete with transom. thanks
Don S
Re: can someone help
There isn't enough information there to even answer your question.
I have to assume you mean you have a boat with a 270 outdrive attached to a transom shield on a boat that doesn't have an engine. If that is the case, then what was the original engine in the boat?
Why didn't you use the thread you started at 5:17 to post again,...
Rather than starting a 2nd thread at 6:29,..??
2 threads about the Exact Same Question is totally confusing to the regulars here who are trying to Help you,....
Please don't do it anymore,..... Thank you......
Btw,......
Welcome Aboard to the forums here at iboats.com.........:)
We'll need to know what the 270 was hooked to before,..??
