Can new Stator or Timerbase kill old powerpacks?
cdods
1980 Johnson 100.
Quick Summary. Boat ran rough. Diagnosis pointed to timer base and startor. Replaced them. Now boat won't start and diagnosis suggests both powerpacks have failed. Could new timer base and / or stator have killed the power packs? Details below.
Boat has been running very rough for a while, but it did start and run. Did diagnoses and discovered wires on the timer pack were corroded and failing, and stator while still working was failing - weak with black goo running out of it.
So I bit the bullet and bought replacements for both. Now the boat won't start. I have absolutely no spark on the left side, and extremely weak spark on the right side. Measurements as follows (using CDI DVA adaptor)
Stator
Resistance: Ok as per CDI guide.
Both Sides Disconnected - 190V
Right Side Connected - 190V
Left Side Connected - 120V
Timer Base
Disconnected (Left & Right, White to Blue & White to Green) - 0.6V
Connected (either or both sides) - 0.2V
Based on the CDI guide, this suggests the powerpacks are both bad. What I can't figure out is why if they are bad, the boat ran before I replaced the parts?
Thoughts? Suggestions?
Thanks,
