Hello Everyone. Well this is my story and as the saying goes I am sticking with it =)
I removed my outboard to change all my gaskets, also oved my lower drive unit change impeller and gaskets. I changed the oil everything was working perfectly before I removed the outdrive. When I placed the outdrive back on I am able to move my propeller in neutral, In foward it is geared properly but when I move my throttle to reverse t stays in Neutral as if it does not go into gear. A mechnic came to my house and is telling me I need a shift cable. Can this be true. Reason I am asking is because everything was working perfectly in all my gears before I removed the Outdrive. Suggestions. I am new and I do not want to be taken by surprise and spend an arm and a leg. It is very hard to find a mechanic in Norwalk CT. Most of them are booked for like 3 weeks in advance. If anyone knows of anyone in the area I really would appreciate it.
Engine is an Alpha One Mercruiser 3.0 Gen 1 200 HP.
