Can I rebuild these?
Zraden
Finally found the casting numbers for my rams
Mercruiser 14034 -1 and 14035 -1
But I cant find a rebuild kit listed for them.
Also, the local marina called me back today :facepalm:
There listed at $500 A PIECE !!!! For new ones if I cant rebuild them.
The marina says they don't have a rebuild kit listed
Am I headed to Ebay?? :confused:
Don S
Re: Can I rebuild these?
What are they and what are they for, I don't memorize part numbers.
Zraden
Sorry Don. There the trim rams from a 1990 merc alpha.
thumpar
Check out the SEI rams. They are cheaper than a rebuilt kit.
Zraden
Yeah.. I'm just wondering how much I'm going to get nailed on duty plus taxes to bring them across the
border. Im almost tempted to rent a PO box number in the states to have parts delivered to. Then I can just go pick them up myself and bring them across.
Alumarine
Check out montanashippingdotcom. I'm sure there are other services.
artificialreef
Ok, i may be mistaken and old salts here correct me if i am wrong. The mercruiser manual lists those as the longer shaft version of the 98703 and 4. I rebuilt mine with kit number 18-2649, right here on iboats for 17.00$ If its only the shaft that is longer why wouldnt that kit work? Yes you can rebuild them.
carribbean soul
ALSO why cant you just go to a hydraulic repair shop and get replacement o-rings, the only thing special that may need replacement is the aluminum end cap.
