Can i make a teleflex 479 cable fit?
Sheps2007
Hi All,
i have a 1977 70hp johnson outboard and i need a new gear control cable. problem is here in the UK i can't get hold of a cable to fit. the teleflex 479 type cable fit 1979 onwards and apparently i need a 400 type cable. the difference as far as i can see is at the control box end. so my question is..... can i make the 479 cable fit my control box by adapting it in any way?
cheers
Sheps.
5150abf
Re: Can i make a teleflex 479 cable fit?
I have jury rigged my share of things and have found few can't be done if you put your mind to it.
If the control box end fits then I really don't see why not, a cable is a cable, just remember if your fix doesn't hold you are stranded so be fairly sure it is going to work and hold up.
