projo198
Thread starter- Joined
- Jul 7, 2012
- 317
Today I decided to take a closer look at my ESA now they I have a half-@ss knowledge of what I am doing.
Manually pushing the lever did nothing, the idle stayed the same.
I checked the ground on the ESA to the battery and it was good. I ohm tested the interrupter switch ad though I don't really know how to read ohms it pushed current through when pushed.
To get a better idea on the switch I wired one end of the switch wire to a known ground, and the other to the negative post on the ignition coil. Whammo, it stuttered when the switch was pushed.
I then put the test wire to the factory wire harness that comes from the motor to the ESA. With the wire on the brown wire it had the same effect, so that should eliminate a wiring problem.
All that being said, is there a reason why I cannot wire the interrupter switch directly to the ignition coil, instead of buying a new ESA? In my mind it would do the same thing, just without the safety of the override switch.
My boat came with an extra ESA and neither worked.
