Can hole in boot be patched? Lake water use only
joesego
I have found a small hole in the boot of my I/O. It seems someone backed into the dock and punctured a hole in the boot about the size of a pencil.
airdvr1227
Re: Can hole in boot be patched? Lake water use only
Which boot? Is water coming in?
CobiaXL
Banned
Local hardware store has "thru the roof" rubber roof sealant....Works for temporary fix but you really shouldn't rely on it.
superbenk
Nope. Nothing will hold for very long. A new boot is only about $100. Inexpensive fix for a part that will sink your boat when broken.
Joshua Nichols
Yeah what he said...
Fix it.. Time to learn how to do it.. Part of I/O owning...
MRS
Fix it and grease u-joints while you have outdrive off.
a70eliminator
Depends on the condition of the boot overall, I patched my raw water intake hose with a hot patch made for a tire patch, against all advise given here, it's still there to this day several years later, the hose had been punctured with a screwdriver doing something stupid. Granted it's not something will sink my boat if it doesn't hold.
southkogs
I'd put a new one on if it were me. Or make sure I keep movin' :D
Don S
Here are the only "Boots" on a boat that can be fixed with a patch.
So the answer here is unanimous, replace it for the 100 or so $, it's way to important to have that hole become something worse over a weekend..
What is some of the things recommended for a proper boot inspection? What do you look for, for ware, before a puncture happens.
a70eliminator
Cool, I was under the impression they were no longer available, for whatever reason.
superbenk
Make sure it's in right side up. There shouldn't be any odd creases where it looks like it'll wear a crack fast. If it doesn't fold neatly and evenly, it's probably upside down.
mcleaves
ignore......
