can any one help me to understand
trendsetter240
Re: can any one help me to understand
ok good ill try that one is there a way i can pic the Solas Amita at west marine i want to go to the keys on Saturday :D
Wish I could help you there but I'm in Canada, I don't know what the west marine store in your area will carry.
mannydvk11
for what i see they have quicksilver,mercury marine,turning point
trendsetter240
I don't really know enough about those props to make a recommendation. I did run a Turning Point hustler prop for a season but I wouldn't recommend that prop for your application.
I'm sure there is somewhere in Miami to buy a Solas prop.
mannydvk11
My friend just call me and told me he have a 14 1/2 X 21 mercruser that if that work for me I can get it for free he had it on his old boat and is almost new only use 3 time now he have no use for it will that work
bruceb58
As long as its fits a Mercruiser Alpha. Would be good to try. The one you have is a 15" diameter so you are going up 4" of pitch but the RPM will be a little higher than if you went to a a 15x21.
What was it used on before?
mannydvk11
On a mercury outboard but he sold the boat and now have yamahas
bruceb58
Depends on the size outboard.
mannydvk11
here it is my new prop
trendsetter240
Does it fit on your drive? It's hard to tell from the picture but it looks like the hub is missing. Or is it just covered in grease?
That prop should definitely be better than your current one and based upon how it performs you can decide if you need to purchase a different one. It's always good to carry a spare prop as well.
mannydvk11
the hub is perfect i already install it on the drive everything drop right in place ill sow some pictures tomorrow and will try to drop it in the water tomorrow afternoon o saturday morning will have some pics and yes i will keep the other prop in the boat just in case something happens and i will get the 4 prop to give it a try to
trendsetter240
Sounds great. Good luck on your trip. Wait until you see how this prop performs before buying the 4-blade because you may not need it!
Cheers
mannydvk11
well guys i took the boat out today i am really happy with the performance at idle i know-this i was not able to hit pass 38 MPH probably am doing something wrong o how to get to plain o how to get the boat to get more speed i also was testing with the shop meter and the reading i was getting was 480 X 10 = 4800 WOT @ 38 MPH gps i do feel my engine is allot more smooth i don't feel the drag on idle and it have good power do you guys think i can improve the MPH can i do better o that's it BTW my tachometer on the boat was @ WOT 6800 RPMs i am looking for a replacement any subjection's thanks
mannydvk11
here is the prop on the boat
bruceb58
So 4800 was WOT? no more throttle left to go? By the way, 4800 is to high. You shouldn't run above 4400.
mannydvk11
yes i had no more throttle left to go and the reading was 480 i figure with the movement noise and probably the connection bouncing around i was getting probably less but 480 was the number every time i tested one thing i have to say it did not sound like before this time the engine sound better like it was running at normal speed with the other prop i was able to get the speed a bit faster but the engine was loud
trendsetter240
well, you're better off now than with the old prop that's for sure. However you should be getting better speed than 38mph. I still stick with my original recommendation for the 12x21p 4-blade but it's hard to say if you will see a significant difference over this prop.
If you want to spend some money the solas HR Titan stainless 4 blade is an excellent prop. But I just don't know if you will see enough of a performance increase to justify the extra expense. It's up to you. I do believe the HR Titan would bring your RPM down to a more reasonable 4600 at full throttle.
Cheers.
mannydvk11
Cheers.
thanks
i do see lots of differences now i will give it a try for a bit but i will go to the 4 prop it might be stupit for me to ask but what if i go with more pitch will it make a differences in the speed
DHag
I've read through this whole thread, just to see how it came out. I don't know why. I'm in a different world: fresh water with a bass boat.
For curiosity's sake, I did a little on-line research on your boat. I think you're expecting more top speed than it can give you. I read through a couple dozen reports and ads on your model, and the top speeds listed are ALL 38-40 mph.
Think about it.... it weighs over 4000 pounds and it's a V hull design. That's a lot of weight and friction, pushed by only about 300 horses, and a single 19" prop. The guys can talk about prop slip all they want, but I think 38-40 mph is all you can expect. It's unfortunate that Larson saw fit to put a 60 mph speedo in it. That just raises expectations.
You were right to be concerned about WOT RPM, and that "dragging" feeling at cruise. You definitely needed a different prop. A 4-blade prop will probably make it feel a little better at cruise, and save some on fuel. But it could knock 1 or 2 mph off the top speed in the process. But if you think about it, the only people who run WOT for more than a mile or two are racers and professional bass fishermen. "Cruise" performance is way more important for most everybody.
If you want to run 60 mph, then you have to shave a LOT of weight, increase power (a bunch), and/or get a different hull design. My bass boat is 17 feet, weighs less than 1400 pounds, has 150 horses, and runs over 60. It cruises sweetly at 45 mph. But then, I wouldn't dare take it off-shore, or expect to sleep inside it, or expect my wife ever to be fully comfy on it. (She thinks we need a boat like yours. :rolleyes: )
mannydvk11
really good i was under the imprecision my boat was faster but i really understood now and my boat feels better with this prop at cruising speed
about what you wife thinks lol she is correct in a way i have kids and i take them out in the boat is so comfortable if they want to take a nap if is raining lol if they need the bathroom yes that is good to have but i have to say this I LOVE FISHING lol and my boat is not comfortable for that that's when me and you don't think like the wife lol
i have to say also thanks to every one with there comments they really help and this forum is grate because it connects all of us and we all learn
