bruceb58
- Mar 5, 2006
- 30,819
Re: can any one help me to understand
So was the boat tach indicating 6000 when your shop tach was indicating 5000?
I still would like to know how your boat ended up with a 1.81:1 drive ratio. Either the boat was sold for high altitude use or the drive got swapped at some point.
Keep in mind that if you do go to a 4 blade prop, its going to drop a couple hundred RPM or so so you may have to drop an inch of pitch to compensate.
Very good news! That's because you hit the rev limiter.. Now the big question is do you go up 2" or 4" of pitch. I am thinking 4".according to the shop tach i can only go 5000 rpms no more then that
