Can a sparkplug gap cause vibration?
rsimmons42
I recently ordered the OMC Service Manual for my motor. 1977 70 hp johnson.
The service manual says .040 gap on the plugs, everything else I read says .030.
I pulled the plugs and gaped to .040. I then went on the water and the engine had a vibration that I could feel through out the boat. Can a gap cause this vibration.
Checked plugs when I got back, no fowling.
Or can the timing being off a bit cause this vibration.
tashasdaddy
Re: Can a sparkplug gap cause vibration?
they run better gapped at .030. unless it is missing, i it should not cause a noticable vibration, i would check the prop for damage, even a bent prop shaft.
rsimmons42
i checked the prop, it is in excellent condition, and I ran a true line across the center of the prop shaft and spun it. it is holding true. IS there a torque value for the prop nut on this engine 1977 70hp johnson.
rsimmons42
thr prop is in excellent condition, and I did test the prop shaft, is there a torque vallue on the prop nut for this engine 1977 70 hp johnson.
and can the timing cause the vibration. I am in the process of adjusting the timing due to replacing the Stator, Timing Base, Power Pack and the Coils
tashasdaddy
any type of mis firing can cause vibration. but what you are saying seem intent. did you torque the flywheel to specs? i have always just tighten my props down, to the nearest space for the cotter pin.
rsimmons42
yes, The torque value said 100ft/lb I torqued to about 120
